Create Multiple CLI Users
You can create up to seven new CLI user roles on the switch, in addition to the three default CLI user roles. The user name must be unique. If you enable the hsecure flag, password complexity rules apply to all users.
You must use an EDM account with read-write-all privileges to create new CLI users.
Use this task to create multiple CLI users on the switch using EDM.
- Select General.
- Select the Multiple Users tab.
- Select Insert.
- Type the ID.
- Type a unique user name.
- Type a password.
- Select the access level.
- Select Enable to activate the user account.
- Select Insert.
Multiple Users Field Descriptions
Use the data in the following table to the use the Multiple Users tab.
Name |
Description |
Id |
Enter a unique integer between 1 and 10. The Id identifies this user on the switch |
Name |
Specifies the username. |
Password |
Specifies the password the user must enter to authenticate. Note:
The password can be up to 80 characters long and cannot contain the username in either forward or reverse order. |
Level |
Specifies the user access level.
Enable |
Check this check box to enables the user access on the switch. |
Type |
An autogenerated value that identifies the type of user as follows:
